Has anyone had the fuel filler pipe fix done? The dealer tells me the fender removal is quite invasive. Unfortuantely, I continue to have both the engine light and stalling problems. Looks as if I will not have a choice
Gary
Quote:
Originally Posted by HiloDave
I have about 3,000 mi. on the car and it normally idles between 700 and 800 rpm. Lately, as I come to a stop in city driving, the engine frequently - but not always - idles down to about 500, feels like it is going to stall and then speeds up again to 700. It has actually stalled twice. The engine temperature is usually under 200 degrees when this happens and the air conditioning is on.
Everything else seems to be normal. Is this something that might be fixed with an adjustment? Should I try a different brand of gasoline (I am using Shell)? Should I just get used to it?
Aware of problem. Issue is with the fuel filler pipe. The dealer can run a quick check but the car cannot have more than a 1/2 full tank of gas. They can quickly determine if yours is another with the fuel filler pipe problem.
It is a relatively easy fix once they order the part. Requires right front fender removal.
Dave
Gary
Dave
