Ford GT Air Inlet Support
Simon
1,265
Is there a way to tell if one has been installed without taking the inlet off? Thanks
MNJason
2,097
San Diego
It should be much more solid if it has it. I would think it would be quite apparent.
Superfly
HERITAGE GT OWNER
2,210
Squeeze the inlet. If it's not 'squishy', (ie. if it's completely unable to be squeezed) then you've got some support in there.
Simon
1,265
It is solid, and I suspected that it had one installed. Are they common upgrades with the throttle body? Thanks
debtdrives
438
Oakland, Michigan 48363
A small one is factory original. A larger one is from accufab
Simon,
I'd recommend removing the air cleaner and take a look.
It is simple, two 10mm bolts on each end and loosen the oblong hose clamp at the inlet.
That way you can poke your nose into the inlet, take a flashlight and see exactly what you have in there. :thumbsup
SSRob
542
Oklahoma
I bought an inlet support and for the life of me could not get it to go in all the way. Gave up after about 30 minutes. Even tried using soapy water to give it some slide. Any suggestions?
4,219
did you remove the stock one first that is inside?
small band a couple inches wide - worthless
