For those with a service manual.........
M
Mark O
I'm swapping out the gray calipers to red, and am in need of the torque spec for the caliper mounting bolts. While I'm here, is there anything else I should know about?
THANK YOU in advance!!!! :cheers
Pete S.
529
Torque Specs
Description ...............................................NM..................lb-ft
Front disc brake caliper bleeder screw.............14...................10
Rear disc brake caliper bleeder screw..............14...................10
Brake tube nut............................................16...................12
Master Cylinder brake tube nut.......................16...................12
.................................FRONT...............................................
Disc Brake caliper mounting bolt.....................100..................74
Front brake hose..........................................34..................25
Brake disc retainer screws..............................27..................20
Hub & bearing mounting bolts..........................90..................66
.................................REAR...................................................
Disc Brake caliper mounting bolt......................100..................74
Rear brake hose-to-brake disc caliper...............34..................25
Parking brake caliper mounting bolts.................70..................52
I haven't read the section or done the work, so not certain if there's anything else unusual about the process. I'm sure someone will chime in.
Pete S.
ViperJoe
1,305
Washington Crossing, PA
EZ swap, no surprizes ..... I went from red to gray!
M
Mark O
How about Gray on one side & red on the other? :lol
FlorIdaho Chris
Yeah, I've got one.
Why stop there? How about a different color on each wheel! I think I have seen a yellow caliper on someone's car. I say black, yellow, red and gray all the way around.
snaproll
215
Naples, FL
good n tite also works on those caliper bolts. Most importantly, I would not let the MC drain low enough to let air in from the top side of the system. I've had a hell of a time getting air out of the ABS systems in mustangs. Not sure about the GT's in particular
