Engine seems to miss in higher RPM range, Any thoughts?
dandaman
113
Tyler, Tx
I replaced the fuel relays and changed the plugs to NGK TR6IX plugs and it seemed to fix my problem. Thank you all for your help!
941
Now test the rev limiter
Art138
631
Weston,FL
Those are the plugs that solved my problem gaped at .25
.25???
So, could it have just been the plugs and not the relays?
Art138
631
Weston,FL
.028” With the Torrie tune since it causes a short intense spark. Just re-checked I was advised to gap at .028 vs 025” which I did.
For certain, it was NOT the relays.
Reactions: analogdesigner
941
Relay should set a code, misfires don't always set codes(for some reason, year?)
