Electrical tech tip of the day
If you need to tap in to the electrical system this is a great option. This device plugs into the existing fuse slot. This device maintains the original amp rating on the original circuit and gives you a second fused circuit for your use. Easy to use and no soldering. It's called "Mini Add-A-Circuit" made by Littlefuse Inc part # FHM 200 ZP , OFHMO200ZP. I found this at Pep Boys but I have seem them in other places. I needed a 12 volt constant power supply there is two options in the SJB. Slots 4 & 6 I choose # 4 Accs. Delay & Ign. vs # 6 which is the Brake Pedal Position switch & Pressure switch. Didn't want to take any chances with the brake system. Pictures are as follows:
1) Package that part came in
2) Fuse device before installation
3) Fuse device inserted into fuse block
I have used these on many projects so I alway keep one around just incase I'm in the lighting mood!!!
Hope this is of some use. My mother said Sharing is Caring...:biggrin
Yes sir they are a wonderful piece and a great item to share. So much better than soldering a wire to a fuse or for than matter splicing into an existing lead.
I keep both the mini and the standard fuse version of these in my facility at all times.
We have used them for several years and they are a "PERFECT" way create a power tap while retaining the OEM fuse and then allowing one to define an alternate AMP rating all its own on the added power tap.
analogdesigner
950
San Clemente, CA USA
Thanks for the info
I agree,
The problem with the GT is that there are no power taps available within the wiring harness. So this is a clean way to tap into car's electrical system without cutting wires.
Thanks for the info. :thumbsup
Jay
ultrasportracing
491
Perth Western Australia
Anyone used the standard radio plug, for a 12volt source, There are 2 one for the sanyo and one for the proper stereo
Wwabbit
1,259
Knoxville, TN
Cool.Thanks for the post.
ultrasportracing
491
Im using the extra radio plug for a constant 12volt supply for a reverse camera, easiest option to get 12v
