This link seems to imply that Dynojet's HP numbers have a built in correction factor to est. the power loss from the crankshaft to the rear wheels. So that what Dynojet gives as a SAE corrected HP number is more closely related to crankshaft HP rather than RWHP. This assertion seems consistent with the HP numbers often sited for a stock GT, whereby then numbers are close to, or exceed Fords spec 550hp at the crank. Also this site claims tuning on an inertial dyno is inferior to tuning on a load bearing dynos for real on the road performance.
This site seem to have an axe to grind with inertia dynos, Dynojet in particular. I don't know if true, or he is just trying to differentiate his services from others. Dynojets seem to by the most prevalent dynos in use.
Any opinions from the experts?
http://www.germanmotorcars.com/Dyno_load vs inertia_1.htm
