Dyno work
tiger 6
234
virginia
I'm getting ready to make a couple of base line dyno runs.For those of you who have had your cars on a dyno,what attachment points did you use for the dyno tie downs? Was it necessary to remove anything under the car to reach these attachment points? Any other "tips?"
Thanks.
Thanks.
Don't cringe, but using the front wheels is the best for the front points. FOr the rear, an axle strap through the a arm works great. But, the tie down in the rear will have to be straight back from that point or else it will get into the tire.
Ken
We took the rear difuser pan off to solid points of attachment.
Do a search as this has been discussed before. There is no real need to remove any of the bottom panels to secure the car IMO.
Dave
