diffuser repair
I know this has been done before, but the material I used was a bit different and easy to use,
I had recieved some damage to my diffuser as I tried to get into a parking lot that had a rather sharp incline.:ack
I used this stuff called fast steel(epoxy) and a can of black paint. thats it. the fast steel is easy to use. take a piece and mix it in you hand, it has the consistency of play dow,
once mixed just apply to the damaged area after the area has been prepped by cutting some undercuts in the damaged area for better retention.
then grind off the excess I used a dremel tool and final shaping you can use a hand file this stuff works well and cleans up well.
then just give it a light spray of black paint,
:thumbsup:thumbsup
it took me about 45 min not counting taking the diffuser off. and dont ask why the diffuser was off to begin with.:biggrin
HeritageBruce
748
Southern CA
Soroush,
What is the Loctite Expoxy for?
Soroush,
sorry bruce I just took a picture of both of them I bought it to try it and didnt like the consistency so I didnt use it, it just so happend when I took the pic that one came along for the ride.:biggrin
Jones
267
Orange County, CA
Soroush-
Can you fabricate a better story next time...:bored
How 'bout you hit the NOS and spun into a 720, almost pulled it off but the driveway you were pulling into had to much of an incline. :thumbsup
You did a great job
Thank you for sharing the process
nice work!
06fordgt
1,910
Toronto Canada
Excellent and cheap fix. Thx for the R&D on this one.
Jason's Auto Spa
1,272
IL & AZ
Very cool fix!
tmcphail
GT Owner/Vendor
4,103
St Augustine, Florida
Hey thanks for the new weekend project you just handed me :biggrin:biggrin
this project was actully fun and when you see the results it makes you feel better you didnt spend 1500 on a new diffuser, now when I see inclines I just say "bring it on":biggrin
Do you think this will this also work to fill in slight scratches under the front splitter?
tmcphail
GT Owner/Vendor
4,103
Right on ! if you do ever need to replace it though I can do a lot better then that.
Again thanks for the tip.
no, the front splitter is plastic and flexible, this material is not as flexible as the front splitter, so if you put it on it will probobly break off, besides the front splitter is only 140 dollars so its relatively cheap to replace, compared to the 1500 dollar diffuser.:cheers
Superfly
HERITAGE GT OWNER
2,210
:lol:lol:lol
Great writeup of the repair soroush. And you did a masterful job both with the photoessay and the repair itself.
There should be a Technical section full of these kinds of tips (I keed, I keed, I know it's here, and I LOVE IT, so much useful information). :thumbsup:thumbsup:thumbsup
Great work! :thumbsup
Much easier than the way I did it with liquid epoxy. You must have watched those epoxy putty commercials on TV :lol
somelee
409
New York & SoCal
you think I could replace a couple of fillings with that stuff? Be alot cheaper than going to the dentist. :biggrin
tmcphail
GT Owner/Vendor
4,103
Inside out joke hahaha
:lol are you scared of the dentist? :devil the dentist is your friend:biggrin
