Cooltech charger
TEXAS GT
2006 Twin Turbo
I just recieved the charger system from Cooltech. I am very impressed with the quality of the connections and how well designed it is. I expected a much more generic set up but Kendall has really built a custom setup just for the GT. I don't plan to drive the '06 much so this was a necessity. One less thing to worry about.
Good job Kendall.:thumbsup
Kendall has presented several wonderful pieces for the GT each very well thought out
Regards
Would you put a link to the info please.
www.cooltechllc.com
Looked at the site. Seems good.
Do you need to cut, splice, or drill (in other words modify) the GT?
No, but you do have to drop the driver side of your front spoiler which is not that big a deal. Also make sure you have a T27 Torx 1/4" drive socket before you start so you can remove the bolt necessary to mount the plug in the front grill. If you want to shortcut the install, you can just wiretie the mount to your tow.. bolt.. hole..thingy...:lol
