I would suggest you use the search function on this Forum. Shadowman provided a very detailed explanation with pictures on how to remove it.
Here's what Shadowman sent to me:
The center console is removed as follows;
Blue tape around the stereo, around the protruded started button bezel, and along the edges which are approx 45 degree angles where the center console and the center of the dash have a seam line.
Then remove the leather trim panel in-between the seats; 3 Torx on each side; NBD
Then remove the black side panels that are along side of the seats; it is simply secured with 5-6 Velcro squares 1” x 1” every 6-8 “ along the top as such a credit card or ? works well and once you get once free slide your finger and pop one loose at a time. Rest assured that the panel is TUFF and you will not cause any damage. Once the Velcro is freed the panel simply sits in a receiver slot all along the bottom
Then tape around the e-brake bezel, the handle, and it will pull nearly straight up; not at an angle as it appears. It is secured with nothing more than 4 metal pressure clips so it may feel more ominous than it is; once it begins to come up it is easy. Remove the shifter knob; loosen the nut and spin it off careful not to drop it. You DONOT remove the e-brake handle but rather it is lifted into the max park position and you will be removing only the rectangular bezel around its base which is secured with 4 pressure clips
Once this is all completed… refer to my instructions the console will ultimately be lifted over the e-brake handle
We are almost there.
Now remove the 4 Torx on both sides that secure the center console in place
Now it helps to have a small 4”-6” piece of 2x4 block for the next step.
Slide the seats all the way back and raise the e-brake handle all the way; max brake
Now from the driver side lift the back of the center console and use the block of wood to prop it up (the front will still be in place however you will be creating an angle out of the center console) as you need to look under the switch portion of the center console where there is a electrical connector. You need to press the detent and it will come apart easy. Once this is done now you need to sit in the driver seat and simply lift the back of the console and pull it way from the dash an inch or two at the same time and then you can lift the front over the e-brake and the shifter shaft and “wholla” you now can simply point it out of the car and slide it and yourself out as an assembly. Now if you have a second pair of hands you could remain seated and simply slide it out.
Jer once you have completed the process you will realize that it is not difficult; it simply requires a bit of finesse so as not to cause any secondary damage aka scratches …. Let blue tape be your friend
There are no hidden clips or items of concern
Installation of the center console is easy; to make sure the shifter boot is in place before putting it on and I always have the deadening material tucked into position under the console prior to setting it in place and then once in rough position I plug in the connector and reach around under the console and make any minor adjustments of the sound deadening material and then slide the console into position. Sometimes you will have to pull the edge of the center console out a bit (very slight you will see) to clear the clips otherwise NBD. Once the center console is in place……. 4 Torx on each side…….. black panels…….. e-brake bezel…… shifter knob……… leather center trim by means of the 6 Torx …….. remove tape…… find something cool to place in the center cubby…… and then smile…..
All the best
Bill aka Shadowman
