- Dec 17, 2011
- 412
ok this is a head scratcher. I made 19 psi with a manual gauge on the dyno with a 4.0 whipple with tune/ mafia/ford racing exhaust stock headers / no cats/. 52lb. when i got home i only saw 10psi (found out later with the mafia the stock gauge will only show 10 psi. I then hooked up a two different manual gauges to see if that was the problem. made 13 maybe 14psi in second gear under load up to 7000 rpm and never dropped/ I then tried all of this in some order not all at the same time / put on a new Belt (its tight with good belt wrap) I then put on a new Bypass actuator from whipple/ I spayed brake cleaner around running engine to see if I have any vacuum leaks. We hooked up the Bypass with the boost solenoid off/added boost to the top of the bypass / zipped tied the bypass arm down with arm off bypass actuator so the computer or actuator can not open or bleed off boost. checked plugs to make sure engine is not hurt. (car runs perfect and has 20 plus vacuum. took off the air box and check K&N filters. made sure inlet tube could not collapse (has inlet tube sleeve)/checked intercooler pump/ checked blower on the car with belt off and it spins good and has no noise from hitting blades/ called Rich from Gt guys/ confirmed with the tuner all the settings are right/called whipple and they do not think it is the blower and said if it spins with no noise all should be good/ i am lost and i think i checked everything. The car does not smoke or pressurize the coolant system or over heat. cars sounds great but just feels like 13 psi. The only thing that is different is on the dyno the shell was up and on the street the shell is closed. can the shell restrict 5psi? the last thing unless someone else can give me some advise i am missing is to re dyno the car with the top up or take off the blower and look at the bypass blades but the car made 19psi so i am not sure why that would change. ok i owe someone huge if you can help because this is a three week adventure and I am burnt out. i checked way back in the archives neep heeeeelp.. lol i hate begging for help.
