Everyone,
If you are interested in ordering one of these, you may do so by sending $37.00 plus $8.00 (shipping and handling) totaling $45.00 by check or PayPal. If you order multiple units, please only pay for shipping and handling once! I will be placing another order for parts this coming week and I will process your order ASAP. I want to thank all of my prior customers for their positive comments on the build quality and ease of installation.
Also, I am looking into a designing an isolated +12 volt power supply for supplying clean, controlled, precision power to the gauges. First, let's see how things work with this current scheme. Thanks all, Jay. www.analogdesign.com
By check, $45.00 to:
Jay Philippbar
2006 Via Solona
San Clemente, CA 92673
(949) 412-8889
gtsaver@cox.net
OR
By PayPal, $45.00 to:
gtsaver@cox.net
PLEASE MAKE SURE YOUR MAILING ADDRESS IS INCLUDED!
My personal website:
UPDATED on 4-21-2015: I have found a special "grounding washer" that fits perfectly to solve the problem that jcthorne has identified. The washer is designed to penetrate the paint on the panel to ensure a good ground connection. Please see the images below. I will be doing additional updating on this within the next few hours. I am going to be mailing out two washers with instructions to everyone by the end of the week (as soon as the parts arrive). Jay
Hello everyone,
Sorry for being gone for so long as 2014 was my year from hell.
During my time off last year I have decided to design a device that may provide some additional protection to our gauges. First of all I have always had the belief that most of the gauge failures are due to a voltage transient on the car's electrical system. This could be a very short duration high voltage spike or even a reverse voltage spike. I had built a simple device that clamps any unwanted voltage transients regardless of the polarity. This is simply a special selected diode that clamps any voltage transient that exceeds 15.5 volts as well as any negative voltage greater than about -0.8 volts. The basic assembly is shown in the first image. The fuse adapter on the left is a Littlefuse “Add-a-Fuse” which plugs into the fuse block where the fuse for the gauge cluster originally was. The original fuse for gauge cluster is now plugged into this adapter. The second fuse is for the protection diode; in case it shorts (if it shorts then it WAS protecting the electrical system!). The second image shows it installed into the fuse block in my car (note the yellow arrows). Note: my fuse block looks very busy because I also have a wideband O[SUB]2[/SUB] sensor.
I am not going to make any claims that this will prevent gauge damage! I had my oscilloscope setup in my car and monitored the voltage going to the gauge cluster. I was able to see voltage transients approaching 15.5 volts (they were narrow as expected) and with the protection diode it clamped everything to 15.2 volts! I deliberately selected the protection diode to operate very close to the vehicle’s maximum system voltage. With the engine running I cycled through all of the accessories in the car, A/C, headlights, fans, etc. in order to try and make the electrical system as “noisy” as possible. I have been using this for about four months without any problems.
If anyone is interested I can make a simple parts list and/or even build some.
Thanks all,
Jay
Jay Philippbar
2006 Via Solona
(949) 412-8889
gtsaver@cox.net
OR
gtsaver@cox.net
Hello everyone,
Thanks all,
Jay
