Fumoto oil tank drain valve
I installed this to make it easier to get samples for oil analysis and to eliminate splashing on the frame when removing the drain plug. I wouldn't recommend using this in lieu of doing a proper oil change that also removes the 2 plugs on the oil pans. You get another 1 to 2 quarts of oil out of the pan and it is a good time to check the under carriage as well.
Just opening the clamshell you can reach the valve from the top without removing any pans.
The correct size is an M12x1.75, the Fumoto part number is F107N. The tube exit through the hole on the right rear jacking pad. I have to get a cover for the end of the tube so that it will stay clean and not contaminate oil samples to be tested.
